Very successful design
A project log for Adaptive wireless switch
Adaptive switches are often used by people with limited hand function. This switch looks like a game controller and uses a low cost keyfob.
andrew-mitzAndrew Mitz • 07/24/2024 at 11:14•0 Comments
Since the start of this project I have assembled 5 of these wireless switches. The latest version is rugged and reliable. The range of operation is only about 4 to 6 feet, but that works well for my application. As the battery runs down, the range reduces.
I use 500 mAh batteries, but the controller will fit 1000 mAh batteries with no problem. I purchase fresh batteries every 4 years or so, but I actually do not know how long a battery will last.
Assembly is somewhat tedious. The detailed instructions are very helpful.
