The Flip-Byte
Having sorted out the mechanics with the Flip-Bit it was time to extend that to the 8 bits I will be using for the Tape, a Flip-Byte. So I mashed together 8 of the bases used for the Flip-Bit and came up with this:
Then following the instructions for constructing the Flip-Bit 8 times I ended up with this:
Ready to be mounted under the Tape Panel.
