Retro case for Esp node
An inusual old TV case for Wemos D1 mini Pro and HTU21D sensor
Public Chat
I could not find a case that combined practicality and design at the same time and so I drew inspiration from an old black and white TV of the glorious Mivar brand. Armed with patience and helped by the fantastic program "FreeCad" I managed to realize this 3D printed project with an Ender 3. These nodes will be located in the rooms of the house and through an Android software, that I am developing, will allow you to manage the temperature individually.
Body.stl
Standard Tesselated Geometry - 1.17 MB - 07/19/2020 at 15:47
Download
Front.stl
Standard Tesselated Geometry - 276.84 kB - 07/19/2020 at 15:47
Download
Rear.stl
Standard Tesselated Geometry - 247.45 kB - 07/19/2020 at 15:47
Download
Antenna support.stl
Standard Tesselated Geometry - 36.61 kB - 07/19/2020 at 15:46
Download
  • 1 × Wemos D1 mini Pro ESP8266 based
  • 1 × TFT 1.8" Spi 128*160 model KMR-1.8 SPI
  • 1 × Sensor HTU21D
  • 1 × Dual usb female type A from old mainboard...
  • 1 × Circular antenna Copper wire in a 5 cm diameter circle
Michail Wilson wrote 08/14/2022 at 14:44 point
Where is the code to put on the Wemos?
Jacob David C Cunningham wrote 07/22/2020 at 07:23 point
Can you provide more context? I'm intrigued. What is the circular copper antenna for? I'm assuming these have batteries/how long do they last/how often to charge? You mention managing temperature?
Marcello Milone wrote 07/24/2020 at 09:50 point
The circular copper antenna is only for design :D , the real antenna is rear. The project is powered with a cellular's charger . No battery inside. This node is for measure temperature and humidity in every room and report this on the manage software
