I2C Bus Multiplexer
Building a bidirectional four-channel I2C bus multiplexer circuit using the circuit as a level shifter depending on SLG46826 IC
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
In this project, we built a bidirectional 2-bit mux circuit that can be used with I2C lines. The circuit also has the extra functionality of operating as a level shifter, if needed. The design is based upon the GreenPAK™ SLG46826V, although any GreenPAK with I2C can work for this purpose. Due to the bidirectionality of the SDA and SCL lines, this design can be utilized for single-master or multi-master I2C communication.
Learn more: https://www.dialog-semiconductor.com/an-cm-285
