30.08.2020 - mounting all togather
A project log for PAQM - Portable Air Quality Meter
PAQM is a portable device to mesure the air quality. Breathe the fresh air !
nj1337nj1337 08/30/2020 at 00:210 Comments
Then, the first part of the assembly is to screw the main PCB plate into the case that I printed this morning.
Then, you have to put double-sided tape to stick the battery. Hot glue will work too.
Then, we connect the elements one by one to check that everything works well.
and we can mount the next stage of components :
I will have tomorrow to design the upper part of the case with an air flow management system.
Thank you for follwing this project.
