KSA-2 thumbwheel replacement board
So the KSA-2 housing is 10mm thick. Looks like these connectors should work.
https://www.digikey.com/product-detail/en/samtec-inc/SSQ-105-02-T-D/SAM1193-05-ND/1111259
The default KSA2 board is 0.8mm thick, but it looks like once the heat stakes are removed it could accomodate 1.2mm or maybe even 1.6mm thick boards.
I ordered the first round of board from OSH Park. If they line up with the KSA-2 plastic box, I'll publish it on github.
View all 3 project logs
Yohann
Benchoff
SHAOS
Kevin
Yes, delete it Cancel
You are about to report the project "KSA-2 Decade Resistor Board", please tell us the reason.
