TAS5805M I2S DAC prototype
A project log for Loud ESP
I'm looking for perfect audio DAC for ESP8266/ESP32
andriymalyshenkoandriy.malyshenko 06/06/2021 at 20:280 Comments
I've decided to take stakes a little higher and prepared bigger version of previous prototype. New one used Texas Instruments TAS5805M DAC, which is a big upgrade actually
- It have high power stage, producing up to 23W per each of 2 channels (yeah!)
- obviously it requires more than 5V over USB, so i had to redesign power circuitry completely.
- it requires I2C additional to I2S to communicate and few GPIOs to report it's status.
Because power stage took a lot of PCB space, screen went other side of the board for now. On the bright side, i could take a larger screen, since i have plenty of space now.
So all together it is quite a different beast and I'm trying to find time to write firmware to get it started even. I get Ka-Radio32 firmware working on both prototypes and it works brilliantly on PCM5102 version. Currently working on TAS5805M addon to jump start the big thing.
