Project update
A project log for Loud ESP
I'm looking for perfect audio DAC for ESP8266/ESP32
andriymalyshenkoandriy.malyshenko 09/10/2021 at 09:231 Comment
At one point I've decided to create ESP-32 based web-radio in the case of old classic radio.
This one I've bought for around 50 euros, it wasn't working obviously, and frankly  didn't bother to fix it. From one point I'm not a big fan of AM, from the other it has a very peculiar schematics, it runs from mains directly without input transformer of any kind. If you push the socket in the "right" direction all metal parts will be live, so decided I wouln't want to have that anywhere in the house near children playing with screwdrivers.
Going back to the project. I've forked Ka-Radio32 repo, which is a ready to use wifi radio project. What I needed to do is to add HW definition of my board, and more importantly add TAS5805 amp support, since this is the amp I have on the board.
With that done it is relatively easy to fins some space within the box for new board and remote control receiver. Also I've connected power-on switch from the radio itself, and put IR receiver under the front panel
And the final result is below.
Ken Yap wrote 09/10/2021 at 11:03 point
That's a cool retro radio case that you've given new life to. 👍 I can even read the type of the vintage pentode, UF80, 100mA heater for series connection.
