http://midibox.org/forums/topic/21095-lre-4x1-breakable-rgb-led-ringrotary-encoder-pcb-bulk-order/?page=3
https://www.youtube.com/channel/UCk2IFYjyWnbIHcsq2f-wbLA/videos
arduino code pastebin, same as file below
https://pastebin.com/uCgwvZ6d
this code is insanely messy. most importantly, it is written for my big synth with like 40-50 LED rings overall, so theres a ton of confusing code none of you guys will need.most importantly the inclusion of the teensy OCTOLED library which is only necessary if you go beyond 1000 LEDs.
well, i told you guys all you get is the hardware hahaha so thats all on you know. j/k i will try clean this up asap.
i will add svg files for the boards measures asap. sorry guys.
