RGB_LED_RING_CONTROL_v10.3_sd_card.inoarduino code for the led rings. keep in mind this is using the OCTOLED teensy expansion. for only a few rings you need to change the FastLED init stuff.WARNING i did not proof read or clean up or comment this code yet. one day hopefully. same code is in the pastebin somewhere in this hackaday ino - 45.18 kB - 07/07/2020 at 23:01 |
