Finalizing, Part 1
A project log for Sound Processing Shield for Arduino
Add reverb and other effects to a mike input, and have it ready on a speaker output
bobgreenwadebobgreenwade 09/04/2020 at 16:080 Comments
I don't think there's anything more I can add, so I've started double-checking the connections and passive component values to make sure everything's right. It's good that I did, too; there were a few misplaced connections, and I'd especially screwed things up around the MAX4468. While I'm at it, I'm also making one last optimization run around the positions of the chips.
I still need to check everything around the FV-1 and (especially) the MAX11312; once that's done I can generate the ground plating and have this ready for prototyping next month.
