The schematic is very simple, the Si7020 use i2c protocol so it must be connected to pin 3 and 5 on RPi, the fan must be connected to pin 2 or 4 and all other component can be assign at different pins. Currently I use these pins because for me it was the simplest way to design the traces for the pcb.
It is important to say that when I add component(or make trace) in the pcb design I always make this component pads at least 0.6mm. For example if the pad is with size 0.6x0.4mm I make it 0.6x0.6 and this is because my CNC is unable to make it smaller without cutting too much.
For pcb milling I use 30˚ angle bit with 0.1mm tip.
FlatCamp setup
For traces cutout
- Tool Diameter: 0.13 Type V.
- The "Cut Z" should be -0.06mm.
- Enable Multi-Depth with value: 0.03
- Travel Z: 1.2
- Spindle speed: 8000(this is max for my DC motor)
For holes drill and board cutout
- Cut Z: -1.501 *I use 1.5mm F4 PCB so this value should be changed according to your pcb thickness.
- Travel Z: 1.2
I left all other settings unchanged:
bCNC setup
Before start milling I run autolevel and I aways set X-Y steps for probing to be maximum 3mm.
Boris Shabanov
