First Prototype
A project log for ATmega 328 Panasonic Remote
Using an ATmega 328 and an IR diode to make a low power remote replacement for my PV-D4733S
sudo-bashSudo Bash 07/08/2020 at 22:520 Comments
I've completed a first prototype on a breadboard:
Currently, I am testing the button matrix by touching a wire to different pins on the ATmega. The code is using ATmega Timer 1 COMPA and COMPB to oscillate the IR led at the Panasonic carrier frequency and uses the 16 bit Timer 2 to time toggling the carrier on and off.
I am starting work on a second prototype using perfboard:
