S Record Load Character Drops - Sometimes
A project log for Retro 68000 CPU in an FPGA
Making a Retrocomputer with a 68000 CPU in an FPGA
land-boards.comland-boards.com 07/11/2020 at 19:180 Comments
I am getting character drops when loading the S Records - but only sometimes. I had a similar problem  with MIKBUG s-record loads. I solved it there by disabling echo on loads. There is no ECHO on TUTOR when the file is loaded from the ACIA as the second port.
I think there may be a workflow that works reliably.
