Speeding up the CPU
A project log for Retro 68000 CPU in an FPGA
Making a Retrocomputer with a 68000 CPU in an FPGA
land-boardscomland-boards.com 08/22/2020 at 10:000 Comments
The 68000 CPU IC had a pin called DTACK* (Device Transfer Acknowledge). When you grounded DTACK* the CPU ran at full speed.  If you wanted to slow down the CPU for a slower external device you pulled the pin high until the device finished.
The FPGA Core for the 68000 CPU has a similar pin "clkena_in" which flips the sense of DTACK* and "stretches" the clock when it is low and enables the CPU clock when high. The pin was set to high in my design and there were no wait states. This didn't work for External SRAM so I lowered the clock speed to 16.7 MHz which allowed the CPU to access slower External SRAM correctly.
Adding Wait States to Speed up the CPU
I added a wait state counter for the clkena_in signal which is activated when the CPU tries to access External SRAM. This will come in handy if I want to get the external SDRAM working. Here's the code for the wait state counter plus part of the CPU instance..
    -- Wait states for external SRAM
    w_cpuclken <=     '1' when n_externalRam1CS = '1' else
            '1' when ((n_externalRam1CS = '0') and (w_wait_cnt >= "0100")) else
            '0';
    process (i_CLOCK_50,n_externalRam1CS)
        begin
            if rising_edge(i_CLOCK_50) then
              if n_externalRam1CS = '0' then
                  w_wait_cnt <= w_wait_cnt + 1;
              else
                    w_wait_cnt <= "0000";
              end if;
            end if;
        end process;
    CPU68K : entity work.TG68KdotC_Kernel
        port map (
            clk                => w_cpuClock,
            nReset            => w_resetLow,
            clkena_in        => w_cpuclken,
 As a result I was able to move the CPU speed back to 25 MHz with no wait state for any other accesses.
The External SRAM chip select is now 120 nS (3 CPU clocks). It could easily be made shorter since my External SRAM is 45 nS parts. Would still need additional time for propagation delays and setup times so I will leave it as is for the moment..
