BattLab-One Power Profiler Software
A software/hardware solution for capturing current profiles of battery powered devices and optimizing battery life for your projects.
Starting from
$79.00
Bbird has 126 orders / 5 reviews
Ships from United States of America
The Battlab-One Software:
- Estimates the battery life of your IOT project using the DUT cutoff voltage, battery state of
charge data, event duration, and captured active and sleep current profiles (requires Battlab-
One hardware).
- Provides "what-if" optimization by letting you change your battery, current profiles, active and
sleep duration as well as cutoff voltage
- Simulates standard batteries for Li-Ion, LiFePO4, Alkaline, NiMh, NiCd
- Enables a trigger input feature enabling you to capture different firmware states and their
impact on overall battery life
- Long active event capture duration from seconds to hours
- Extremely low burden voltage across all ranges (BattLab-One provides PSU output)
- Features the ability to save profiles so you can compare your DUT current profiles
- Interactive/detailed active current plot so you can look for anomalies and identify performance
improvements for your IOT project
- Open source hardware and softwar
Adobe Portable Document Format - 516.68 kB - 07/21/2020 at 19:44
Preview
Download
Adobe Portable Document Format - 1.20 MB - 07/21/2020 at 19:44
Preview
Download
View project log
Bluebird Labs Doug Peters wrote 07/30/2020 at 22:18 point
Check out my new Facebook page at https://www.facebook.com/bbirdlabs/
