Megadrive PC
PC casemod on a Megadrive shell
PC casemod on a Sega Megadrive (a.k.a. Genesis) using a BAT-TI2 motherboard (Celeron J1800), 4GB or DDR3 and a 120GB SSD.
Computer Specs:
  • Motherboard BAT-Ti2
  • Processor: Celeron J1800 (Bay Trail-D) @2.41GHz
  • Memory: 4GB DDR3
  • Hard Disk: SSD 128GB
  • Wi-Fi / Bluetooth module (RTL8723BE) on mini PCI-express
  • 1 × BAT-TI2 motherboard
  • 1 × Sega Megadrive Shell
  • 1 × Veroboard, 2 x 4 inches
  • 1 × 0.3mm black plastic sheet
  • 1 × 19V DC Power Brick
View all 12 components
View project log
  • 1
    Prepare the case
    Use the metal cover that comes from the motherboard to mark where to cut.
  • 2
    Cut The case - Bottom
    Cutting the case is an iteractive task. All the time you have to check if there's something jamming the motherboard. Try to cut as minimum as possible, specially the parts used to hold the case together with screws.  For this project one mounting pole was sacrivfied leaving the other 3 to be used to hold the case.
  • 3
    Cut the case - TOP
    With the motherboard was fixed on the bottom of the case (using superglued plastic hexnuts/standoffs)  it is time to remove any plastic piece that touches the motherboard preventing the case to close. As before remove the minimum amount of plastic as necessary.
View all 11 instructions
Dan Maloney wrote 07/10/2020 at 16:11 • point
Compact little fella you got there. Nice job!
danjovic wrote 07/10/2020 at 21:55 • point
Thanks!!
It has a cousin a on a NES clone case (http://danjovic.blogspot.com/2016/11/montagem-do-dynacom-pc-concluida.html)
