Hackaday.io Hackaday.io
Sign up Log in
500 laser pointers lamp just for fun
You have 500 laser pointers. What will you do with them?
nanoslavicnanoslavic
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
4
2
5
Team (1)
  • nanoslavicnanoslavic
Join this project's team
completed project
laser light diy decor
This project was created on 07/10/2020 and last updated 5 years ago.
Description
This is my old project, which few people know about. I tried directing 500 laser pointers to one point. It took about six months, but I liked the result. I decided to share it here.
Each laser module consumes about 30 mA at a voltage of 5 V. All modules are connected in parallel. Total consumption is about 15 A.
I used cheap laser modules and materials. Of course, it is impossible to combine all lasers at one point without the exact equipment.
When the laser module is working, it heats up and moves slightly. Therefore, over time, the laser beams are redistributed in space.
The area in which it turned out to combine the laser beams is approximately 30x30 mm.
I used a smoke generator to better see laser beams. It looked amazing!
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
synaptic.axon wrote 09/15/2020 at 07:37 • point
Very nice!  I have >100 of these lasers and one thing I didn't realize at first is that the metal can unscrews.  It is springloaded holding the lens.  You can dial in the focus for each laser individually.  I was pretty happy with the unfocused beam and thrilled when I discovered that.  Did you dial them in at some point?  Looked a bit fuzzy on the target.
Dan Maloney wrote 07/11/2020 at 00:41 • point
Awesome! Now do green lasers ;-)
Ken Yap wrote 07/10/2020 at 23:43 • point
Spectacular. Is it possible to modulate the lasers to produce images?
nanoslavic wrote 07/11/2020 at 04:22 • point
It is possible, but I'm too lazy to reconnect a lot of wires :) I did this project two years ago, I don’t know if the laser modules are working yet.
SOME PECULIARITIES YOU WANT TO KNOW ABOUT...
Project Owner Contributor
PECULIARITIES ABOUT LASERS AND LASER ENGRAVERS.
george-i-fomitchevGeorge I Fomitchev
This sculpture was originally created to capture the beauty of a laser in smoke. It evolved to represent the triumph of finding self-love.
Paralysis
maya-fMaya F
Second in a series of laser experiments
DIY Yag Laser
joseph-lavoieJoseph Lavoie
This instrument runs laser beams instead of strings
Laser Harp
lynLyn
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "500 laser pointers lamp just for fun", please tell us the reason.
Send message
Remove Member
