Supplies
1- Arduino Nano
1-LSM303D - compass - discontinued - Pololu ]
1-lcd 16x2 - generic
1-I2C Serial Module for LCD Display - generic
3-push button - generic
1-On-off button with lock 3D printer for printing the parts
The assembly was not difficult, after designing the structure in FreeCAD, I printed the parts on the 3D printer and placed the Arduino, the compass and the buttons. I made the connection in a mini proroboard.
To make the software, I set up a sketch on the Arduino API with the help of some youtubers programmers. I made the reference in the comments of the main.INO file. I also made some comments. Only they are in Brazilian Portuguese, my native language.
To operate is easy.
1) When turning on the equipment, it will calibrate the LSM303 D, automatically.
2) The menu indicates the magnetic compass. You can navigate to the other functions using the left and right buttons. But the first thing to do is to level the telescope's tripod. To do this, mount the tripod, with one leg turned for the North, if you are in the northern hemisphere of the planet or for the south, if you are in the southern hemisphere. Navigate the menu to "Nivelamento" and press the central button. The indicator shows the values that must be at zero for the base to be level.
3) After leveling press the middle button to stop the reading and navigate with the side buttons to "Bussola Magn" and activate the central button again for the reading. Locate the north. Use the pointer to mark the geographic north, according to your location on the planet. Point the telescope to the north or to the geographical south, depending on the hemisphere you are in.
4) If you want to know the vertical inclination of the observed object, just go to the "Inclinação" menu, activate the reading and place the base of the equipment on the telescope body.
Finally, I put a scale in centimeters, next to the equipment, in case you want to use it on a map for geographic location.
This is the first version. The next will have a GPS, barometer and air temperature and humidity meters. It will be suitable for people who enjoy walking, running or cycling in nature.
Armando Leonardo
Hossein
Alessandro Sottocornola
