Hackaday.io Hackaday.io
Sign up Log in
USB-C PD Buck Converter
Combination of USB-C PD Trigger and Buck Converter
stefan-wagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.8k views
0 comments
9 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.8k
0
9
12
Team (1)
  • stefan-wagnerStefan Wagner
Join this project's team
  • Project Files (EasyEDA)
hardware
completed project
USB-C type-c Pd trigger power power delivery BUCK CONVERTER
This project was created on 07/12/2020 and last updated 6 years ago.
Description
A slightly different approach to USB-C power delivery by combining a PD maximum voltage trigger (IP2721, up to 20V) and a buck converter (MP2307). The output voltage can be selected via the voltage divider (R5 + R6). The maximum output current is 3A.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The MT3608 is a popular step-up (boost) DC-DC converter IC that can efficiently convert lower voltages (like 5V from USB) to 12V.
Project Owner Contributor
Project Name : 12V Boost Converter USB Plug Using
electronicsworkshopselectronicsworkshops
Dual rail USB-PD breadboard power supply
Breadboard-PD
jung-hoon-leeJung Hoon Lee
PSU module for standard breadboards with switching regulators and integrated CH340 USB UART bridge.
Breadboard Power Supply 3.3V, 5V, 12V and USB UART
universal-solderUNIVERSAL-SOLDER
Use a USB-C power adapter as a power supply with selectable output voltages.
CH224K USB PD Decoy
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "USB-C PD Buck Converter", please tell us the reason.
Send message
Remove Member
