RGB HexMatrix | IOT Clock
RGB LEDs Triangular/Hexagonal Pixels Matrix.
HexMatrix is the LED matrix having many triangular pixels. Six pixels combining makes a hexagon. There are many different animations that can be shown on the matrix form FastLED library, Also I have designed digits from 0 to 9 using 10 segments for each digit in the matrix and made a IOT clock. We can also code it to display weather.
Standard Tesselated Geometry - 2.38 MB - 07/15/2020 at 12:14
Download
Screen.stl
It should be 3D print in white PLA
Standard Tesselated Geometry - 1.06 kB - 07/13/2020 at 08:19
Download
Standard Tesselated Geometry - 1.25 kB - 07/13/2020 at 08:19
Download
Standard Tesselated Geometry - 8.09 kB - 07/13/2020 at 08:19
Download
  • 1 × ESP8266(Node MCU) or
  • 1 × Arduino Uno/Nano
  • 96 × WS2811 LEDs
  • 1 × 5V 2A Power Supply
  • 1
    3D Printing:
    • 3D print all given 3D models.
    • Print the screen layer in white PLA.
  • 2
    Circuit Connections:
    • Make all the connections as shown in circuit diagram.
    • GND~-Ve
    • Vin~5V~+Ve
    • DataIn ~ Pin 2
    • Also extend the power supply wires to last LED and connect, to prevent the voltage drop across the LEDs.
  • 3
    Note:
    • If you use Arduino board then you can only display animations,you cannot display time.
    • If you use ESP8266 board then we can display time and other animations on the matrix.
View all 5 instructions
Randy Antler wrote 08/20/2020 at 22:41 point
This is a nice looking project! Thank you for sharing.
I'm trying compile the code for it and while clock1.ino and clock2.ino compile fine, I'm having trouble with HexMatrix.ino because it fails to compile with some errors.
I'm using Arduino IDE version 1.8.13 and FastLED version 3.3.3 and a NodeMCU ESP8266 board.
May I ask if you have any suggestions about how I can resolve the errors?
Many thanks for your help!
The errors are:
Drops.h:24:36: error: could not convert '(const uint32_t*)(& OceanColors_p)' from 'const uint32_t* {aka const unsigned int*}' to 'CRGBPalette16'
     CRGBPalette16 currentPalette = OceanColors_p;
Noise.h:17:36: error: could not convert '(const uint32_t*)(& PartyColors_p)' from 'const uint32_t* {aka const unsigned int*}' to 'CRGBPalette16'
     CRGBPalette16 currentPalette = PartyColors_p; // Starting palette
sketch/Snake.h: In member function 'void Snake::chooseNewDirection(uint8_t)':
Snake.h:134:15: error: invalid conversion from 'uint8_t {aka unsigned char}' to 'Snake::Dir' [-fpermissive]
   snakes[i].d = r;
Mukesh Sankhla wrote 08/21/2020 at 06:50 point
Hi, Thank You!
The HexMatrix code only compiles without any error for Arduino boards only. Choose the board type as Arduino Uno/Nano and compile it. We cannot run the code on ESP boards. Sorry even I didn't notice that as I have tested that code on Arduino Uno and this code was originally written by Scott Marley for his LED face mask,I have modified it as per Hex Matrix.
You can try similar animations from FastLED Library Examples as XYMatrix,Pride2015 and other animations,which will work with ESP boards.
Randy Antler wrote 08/21/2020 at 17:08 point
Thank you so much for the quick reply! I've tried out the examples from the FastLED library and they work great. 🙏
jackytrabbit wrote 08/13/2020 at 05:23 point
Great job done! Beautiful design! If a PCB is used to load those RGB LEDs , it will be much more compact. Do you think about to design a compact version of this?
Mukesh Sankhla wrote 08/16/2020 at 20:39 point
Yes I have designed and ordered a PCB version which is compact. But due to pandemic orders are not delivered to me. But as soon as I get the PCBs I will check them and post gerber file.
WolfieSama wrote 08/11/2020 at 13:10 point
In components you wrote to use esp8266 (nodeMCU), but in pictures we can see a normal esp8266. Do i need to change pins in code. Cus esp has Digital0, and Digital1
Mukesh Sankhla wrote 08/16/2020 at 20:27 point
No You don't have to change the code. The code will work with any ESP board. Just connect the GPIO 2 of ESP8266- 01 to Din pin of LEDs.
Altairish wrote 08/09/2020 at 14:31 point
Very beautiful! Good job.
Mukesh Sankhla wrote 08/09/2020 at 16:07 point
Thank you!
Quoc Hao wrote 08/06/2020 at 06:01 point
Good project, i like it. How to add date and year in your clock ?, example display it after 30s in 5s.
Mukesh Sankhla wrote 08/06/2020 at 07:17 point
Thank You! We are already fetching the date/month/year in the code. All we have to do is make the additional digits. Like in clock_24 code we have digits from 0-24 which represents hour at upper part of the matrix. We have to add additional digits 25-31 for date. similarly month can be displayed at bottom half.
Warren Pinker wrote 07/29/2020 at 22:28 point
How did you get on with the ESP8266 being 3.3V and the WS2811 and power supplies being 5V
Mukesh Sankhla wrote 07/30/2020 at 04:31 point
The ESP8266 is powered with 5V through Vin pin. Vin support 5V. I had no heating issue.
[deleted]
Mukesh Sankhla wrote 07/30/2020 at 04:33 point
Its my pleasure sir.
Maakbaas wrote 07/28/2020 at 15:24 point
Absolutely awesome design. Good job!
Mukesh Sankhla wrote 07/28/2020 at 15:29 point
Thank You!
Irrawaddy wrote 07/27/2020 at 14:05 point
Wonderful! I'm looking forward of it being at tindie.com.
Mukesh Sankhla wrote 07/28/2020 at 04:21 point
Yes it will available on tindie.com after the pandemic with a thin PCB design.
dplischke wrote 07/23/2020 at 09:19 point
Hi Mukesh, beautifull project. What size of LEDs do I need? 9mm or 12mm? Have a good time!
