bean_hopper.scadThis is the single-dosing bean hopper and indexing ring, scaled appropriately to fit the Rocky. Units in millimeters.x-openscad - 3.31 kB - 07/16/2020 at 21:24 |
grounds_plate.scadThese are the grounds sweepers for the bottom burr assembly. They are slightly too big, and the corners need to be cut off (picture in build log)x-openscad - 895.00 bytes - 07/16/2020 at 21:24 |
popcorn_screen.scadThis is the anti-popcorning screen that was an abysmal failure. It's a tight fit.x-openscad - 574.00 bytes - 07/16/2020 at 21:24 |
