Display test piece - smaller.stl
This is a smaller display unit you can use to test fit your parts, before you print out the big pieces. You can use this to tune your settings before printing the big display units.
Standard Tesselated Geometry -
113.95 kB -
07/26/2020 at 21:04
Download
Link_easier_to_print.stl
Caution! See instruction 3: Make sure you adjust this so it prints flat on the bed. It is a couple of degrees off, so it's easy to miss. I have a picture in the instructions that points out what I'm talking about.<br><br>Per a request from adcurtin, here is a trial Link design that should be easier to print. I haven't personally verified, so maybe adcurtin can give us all some good feedback on whether it fits.
59.75 kB -
07/26/2020 at 18:21
Download
Link.stl
This link is harder to print since it has only a small contact area in one place. Once adcurtin verifies it, you may want to use the version called "Link_easier_to_print.stl".<br><br>Caution! See instruction 3: Make sure you adjust this so it prints flat on the bed. It is a couple of degrees off, so it's easy to miss. I have a picture in the instructions that points out what I'm talking about.
59.36 kB -
07/25/2020 at 14:02
Download
kmatch98 - 7 segment display.f3z
f3z -
18.31 MB -
07/22/2020 at 22:05
Download
Hand wheel.stl
2.71 MB -
07/22/2020 at 19:54
Download
Cam F.stl
683.97 kB -
07/22/2020 at 19:54
Download
Cam G.stl
628.01 kB -
07/22/2020 at 19:54
Download
Cam C.stl
528.70 kB -
07/22/2020 at 19:54
Download
Cam A.stl
498.62 kB -
07/22/2020 at 19:54
Download
Cam D.stl
521.96 kB -
07/22/2020 at 19:54
Download
Cam B.stl
408.48 kB -
07/22/2020 at 19:54
Download
Cam E.stl
399.59 kB -
07/22/2020 at 19:54
Download
Gear 13T drive gear.stl
275.38 kB -
07/22/2020 at 19:54
Download
Frame.stl
511.51 kB -
07/22/2020 at 19:54
Download
Gear 33T transfer gear.stl
438.27 kB -
07/22/2020 at 19:54
Download
Pin - Large.stl
30.84 kB -
07/22/2020 at 19:54
Download
Pin - Small.stl
35.24 kB -
07/22/2020 at 19:54
Download
Display - 4 Segment.stl
537.58 kB -
07/22/2020 at 19:54
Download
Display - 3 Segment.stl
485.82 kB -
07/22/2020 at 19:54
Download
JPEG Image -
672.35 kB -
07/22/2020 at 19:54
Preview
