RF Amplifier
A simple HF/RF amplifier using inexpensive, readily available parts.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Work In Progress - basically a clone of the common Chinese kit but with some minor modifications:
- Removed TR relay
- Removed SMA connectors
- Different bias circuit
- Relocated FETs for improved symmetry
- Wound transformers rather than tubes
- Bottom layer is a solid ground plane
