Arduino LoRa RC transmitter and receiver
Control just about anything RC
A long-range multichannel radio controller based around the Atmega328p and SX1278 LoRa modules.
This DIY controller provides most of the advanced features in modern commercial radios.
For extended description, schematics, code, etc., check the linked github repo at
https://github.com/buk7456/Arduino-LoRa-RC-transmitter-and-reciever
Sorry that I didn't make a good detailed video demo but here is one showcasing the GUI.
https://youtu.be/nmHPPKTZYmU
bach minh tuan wrote 05/12/2022 at 10:31 point
It's so great. How about the stability of the connection?. I made RF remote control using nrf24l01, however it lost the signal frequently. Thus my drone always fall down while flying . Can the LORA sx1278 improve this matter?
buk7456 wrote 05/23/2022 at 10:45 point
The connection is stable enough. Tested the link up to 2km away Line of sight  and didnt experience any connection problems at this distance. Of course your range may vary depending on how noisy your environment is.
rk70emomin wrote 09/15/2021 at 09:35 point
The code can be run.But, The main mcu code does not extend to flash memory on Uno. Sketch code size was 35kb.  Please advise. Mr.
buk7456 wrote 10/02/2021 at 14:57 point
It compiles fine with Arduino IDE 1.8.9 and later. Sketch uses 29980 bytes enough to fit in Arduino Uno flash with extra flash to spare.
matiyasm70 wrote 04/04/2021 at 06:44 point
how the transmitter code loaded to the two atmega328
dididikhsan wrote 12/27/2020 at 14:53 point
how to connect atmega328 with lora, the schematic image can't i understand it.
buk7456 wrote 12/28/2020 at 06:43 point
I have updated the schematics. Hope they are now more understandable
