Upgrade Kit to bring your DAFM SYNTH to the newest firmware version
BLASTER firmware_v2-02.zipLast version of firmware for BLASTER. Compatible with MCUs, touch sensor and OLED displaysx-zip-compressed - 66.13 kB - 05/10/2023 at 19:02 |
GENESIS ARCADE firmware_v1-98.zipLast version of firmware for GENESIS and ARCADE. Compatible with MCUs, touch sensor and OLED displaysx-zip-compressed - 696.01 kB - 05/10/2023 at 19:00 |
DAFM ARCADE_user quick guide_v1-98.pdfUser quick guide for DAFM synth ARCADE v.1.98Adobe Portable Document Format - 163.64 kB - 07/04/2021 at 20:51 |
DAFM GENESIS_user quick guide_v1-98.pdfUser quick guide for DAFM synth GENESIS v.1.98Adobe Portable Document Format - 164.67 kB - 07/04/2021 at 20:51 |
Download the software from here. You must sign up first. Sign up and download are free.
Turn your DAFM SYNTH off and disconnect it from the power supply. Insert the USB-to-Serial Converter as shown in the pictures.
DAFM SYNTH DIY KIT
DAFM SYNTH - ASSEMBLED (you need to disassemble the case and remove all screws and spacers first). Some assembled synths do already have the upgrader integrated in the board and no USB serial connector is found. In this case connect the USB directly to the USB connector without the external upgrader.
BOOT0 must be selected as 1. Use the Jumpers or the toggle switch in the microcontroller.
BLUE PILL
GREEN PILL
GREEN PILL (F401). Turn the synth on, push and hold the BOOT0 switch and then push the reset switch
