1Application Download
The application is free to download from GitHub
2Burning the Firmware to USB Component Tester
⚠️ REQUIRED:
- You will need USBasp to burn firmware files to tester.
- You must have AVRDUDE installed in your system in order for following instructions to work.
In Terminal/Command Prompt, navigate to folder's location with firmware files and execute the following commands-
// Setting fuses for MCU avrdude -c usbasp -B 200 -p m328p -P usb -U lfuse:w:0xe2:m -U hfuse:w:0xd9:m -U efuse:w:0xfc:m
// Flashing .hex and .eep files to MCU avrdude -c usbasp -B 20 -p m328p -P usb -U flash:w:./TransistorTester.hex:a -U eeprom:w:./TransistorTester.eep:a
