Application | Built using Electron
07/27/2020 at 03:31 • 0 commentsThe application auto connects to component tester when a right port is selected by the user. The application is available for macOS 10+, Windows 8 and above and Linux.
For macOS users, touchBar support is also provided.
Designing a custom 3D Printed Case
07/27/2020 at 03:26 • 0 commentsI exported PCB design from Eagle to Fusion 360 and designed a case around it. The case is a 2 part design with snap fit design. The tolerances are pretty tight so it cannot be opened easily.
Soldering test wires to tester
07/27/2020 at 03:15 • 0 commentsI chose 3 different coloured wires to the tester. These wire colors will define the colors showing up in custom application. Supported colors are Black, Red, Yellow, Green and White. And added a bit of hot glue to keep the wires in place.
The Assembled PCB Review
07/24/2020 at 06:01 • 0 commentsPCBWay did a great job at assembly service. The components look very neatly soldered and are genuine components as presented by me in the BOM.
PCBs Arrived from PCBWay
07/24/2020 at 05:55 • 0 commentsA huge thanks to PCBWay's Prototyping and Assemble Service for getting my boards fabricated and assembled. They offer great quality boards for a very low and affordable price. They also offer a variety of solder mask options to try. Currently they are running an amazing offer for assembly service, you can get 20 boards assembled for just $30 with free shipping.
Alternatively, you can click the left image to order PCBs directly from PCBWAY. The assembly service was great and turned out to be amazing and the soldering looks great.![]()
PCB Design - Sponsored by PCBWay
07/23/2020 at 22:19 • 0 commentsThe PCB is designed to be the size of a thumb drive with male USB-A connector. The 3 Test Pads are exposed for soldering the test leds onto them. The dimensions of PCB are approximately 34mm x 17mm.
![USB Component Tester USB Component Tester]()
Akshay Baweja
