All electronic devices require power supplies which converts the alternating current into direct current. Almost all the power supplies have a low power factor and introduce harmonic current, even the liner supplies have this issue. Effect of the single power supply may not be significant but in a system where multiple power supplies are used this effect can be considerable. Power factor of the system/ supply can be improved by introducing power factor correction circuits this will also reduce harmonic currents.
SPC7110F is a power factor correction converter IC. It consumes very little power due to the fact that a high voltage CMOS process is utilized in the manufacturing of IC. Many fault protection techniques are also incorporated in the IC.
Features of SPC7011F
  • Very Low Standby Power
  • High-precision over current protection
  • Improved power efficiency at light load
  • No Audible Noise at Startup
  • Soft-Startup and Soft-OVP functions
  • Low current consumption by CMOS process
  • Enabled to drive power MOSFET directly
  • Output peak current of ± 1000 mA
  • Protects the output capacitor by OVP function
  • Open/short protection at feedback (FB) pin
  • Under-voltage Lockout
  • Restart timer
  • Standby function
SPC7011F Replacement Part
UCC28019
SPC7011F Pictorial View
Pictorial view of the utsource SPC7011F is given below, it is an eight pin IC that is available in SOP package
SPC7011F
Pin Description
Pin diagram and pin description of the IC SPC7011F is given below
Pin Number
Pin Name
Description
1
FB
Feedback voltage input
2
COMP
Compensation
3
RT
Set maximum on time
4
OVP
Over voltage detection
5
IS
Current sense input
6
GND
Ground
7
OUT
Output
8
VCC
Power supply
IC Electrical Characteristics/ Specifications
Some Electrical characteristic of the device are given below
Parameter
Description
Value
IVCC
VCC pin current
VCC
Supply voltage
28 V
IO
Output current, sink & source
1000 & -1000 mA
Vinfb, Vincomp
Vinrt, Vinovp
Input voltage FB
                      COMP
                      RT
                     OVP
-0.3 to 5 V
Iinfb,
Iincomp
Iinrt
Linovp
Input Current FB
                      COMP
                      RT
                     OVP
±100 µA
PD
Total power dissipation
625 mW
Ta
Operating temperature
-40 to 105 C
TJ
Junction temperature
150 C
Tstg
Storage temperature
-40 to 150 C
Working Principle
SPC7011F consists of an error amplifier, comparator, chopper circuit, delay circuit and oscillator circuits. This IC performs the power factor correction converter operation by utilizing a boost chopper in critical mode. The switching operation in critical mode is implemented with self-oscillation without any external oscillator. With power factor correction circuits in the critical mod, the switching frequency is always changing due to instantaneous values of the AC input voltage. This switching frequency also changes when the input voltage or load changes. Due to the switching current flowing form built in the inductor, since an inclination of inductor current depends on input voltage and on time is constant, the outline linking peak of the inductor current which becomes the same AC waveform as the input voltage, which enables power factor correction operation.
Applications
SPC7011F can be used in following applications
Power factor correction circuit
Power factor correction circuit using SPC7011F
Circuit diagram of power...
