Hobby servos quadruped robot Build
Building quadruped robot
Following guide from <a target="_blank" rel="noopener noreferrer" href="https://hackaday.io/project/171456-diy-hobby-servos-quadruped-robot">https://hackaday.io/project/171456-diy-hobby-servos-quadruped-robot</a>
View project log
Jiroh wrote 11/12/2020 at 10:06 • point
Thank you for the reply. Each servo position is adjusted by "angleToPulse.py" and checked by "servo_calibration.py". Try to run my robot with "robot_main_RPI.py". I did not touch on other programs, except  /dev/input/event*. Do you have any tweet on other software ?
OilSpigot wrote 11/14/2020 at 14:33 • point
Do you get an error message?
One thing that I came across is you have to have the controller turned on and connected via Bluetooth before running robot_main.
Jiroh wrote 11/10/2020 at 04:27 • point
Hi, I love to see your video. I am in the middle of setup same robot.
Original 4-legged-robot tend to twist arms, may be legs, while not running python code and I found you did some changes on you Arduino code that is mentioned in second video. Could you advice your setup on Arduino code ?
OilSpigot wrote 11/12/2020 at 05:59 • point
I think I ended up using the Arduino code straight out of the Github repository. All of the tuning was done by changing the python code. It took a little while to figure out how it worked, if you have questions about specific parts of the code I might be able to help.
