Parallelizing Operation
A project log for PCB Isolation Routing Software
Convert Kicad PCB files into GCode with isolated PCB Nets
michael-schembriMichael Schembri 08/17/2020 at 08:300 Comments
Tried parallelizing the dilation operation (the one which causes most delay), this weekend.
Using openmp on loops. But have no control on area segmentation.
#pragma parallel omp
Tried segmenting the area in four. Although, I get the same track results, the background is not filled up entirely. Need to investigate more.
