Ammending
A project log for PCB Isolation Routing Software
Convert Kicad PCB files into GCode with isolated PCB Nets
michael-schembriMichael Schembri 09/01/2020 at 20:040 Comments
Update 1: Front and Bottom Layers are shifted and rotated accordingly. So they are always facing PCB side up.
Update 2: output gcode is now into appropriate filenames "front.gcode" and "bottom.gcode".
Update 3: Program cleans up after exit, unless you tell it to.
Update 4: Included "makefile". Now all you need is to type in
make
in the directory.
