MODBUS RTU WITH STM32F4
IO extension board: 8AI, 8BI, 8AO, 8BO. CAN DOWNLOAD THE PROGRAM
Public Chat
Starting from
has orders / reviews
Ships from
Communications Ports2 RS-485 NET1, NET2 supporting:BACnet MS/TP up to 76800 bpsOptional Modbus up to 115200 bps8 Binary input, 8 Universal input (0-10 VDC , 10 k&#x3A9; Thermistor, 4-20 mA), 8 Relay output (250VAC, 5A), 8 Analog output (0-10V)If you want this project (altium and source code), contact me via mail for me <a target="_blank" rel="noopener noreferrer" href="mailto:daovanhoa12@gmail.com">daovanhoa12@gmail.com</a> or my skype id: &#x110;&#xE0;o Hoa (live:daovanhoa12)
Inputs
8 Binary input
8 Universal  input
  0-10 VDC (using the 10V jumper and ON jumper setting)
  10 kΩ Thermistor (using the 10 kΩ Thermistor jumper and OFF jumper setting)
  4-20 mA (using the 4-20mA jumper and ON jumper setting)
Outputs
Device Addressing
Set via DIP switches and jumper
Power
24VAC/DC
Technology
STM32F407VGT6 microcontroller featuring 32-bit ARM Cortex® -M4 with FPU core, 1-Mbyte Flash memory, 192-Kbyte RAM
Real-time clock
Connectors Module SPI, I2C, Ethernet
Dimensions
18.8 x 10.7 cm
If you are interested can contact me via email daovanhoa12@gmail.com or my skype id: Đào Hoa (live:daovanhoa12)
PIN STM32_BM8888.xlsx
sheet - 10.89 kB - 09/23/2020 at 08:18
Download
  • Testing
    daovanhoa12 • 09/23/2020 at 03:54 • 0 comments
    Analog input 10 kΩ Thermistor sensor | Modbus RTU
    Analog output 0-10v | Modbus RTU
    Digital Output | Modbus RTU
    Digital Iutput | Modbus RTU
View project log
