Simple 16 bit soft-core CPU for FPGAs written in VHDL (previously verilog)
Very good progress happened.
First of I've rewritten everything in VHDL, because the very first version of my processor was in VHDL and I feel much more confident with writing it than verilog.
As a second step I implemented a very basic BRAM module, tested most instructions (i just realized while typing this that I am still missing the shift instructions. Lazy me.) with a testbench and wired up the SoC.
Created a simple ROM too which is for the moment directly in the SoC module file and contains just 32 instructions max for the moment, BUT I got the very first program working looking like this:
load 0 into r0
load 1 into r1
load 16 into r2
load 0 into r3
load 5 into r5
add r0 = r0 + r1
set address (leds) 0x5 to r0
set lower than r3 = r1 < r2
branch when r3 != 0 --> 5 (to add instruction)
sub r0 = r0 - r1
set lower than r3 = r0 < r1
branch when r3 = 0 --> 9 (sub instruction)
jump 0
This counts to 16 and back down to 0. And this works super nice! See embedded video:
Pretty happy about this. I think I will implement a very very simple assembler first, a nice ROM module next and then will see where it goes on. The updated VHDL code can be found in my gitlab repository
I think I finished writing the CPU up. Missing are the ROM and RAM.
But I only tested load and addition commands yet. TODO: Test every instruction
See:
What can be seen here?
load 5 into register 0
load 9 into register 1
load 2a into register 3 (Output address)
Add reg 0 and 1, save into reg 2
Display result (0x000e) at address (0x002a)
Looking good.
