side_3mm_tool_caddy.FCStdThe 3d printed tool caddy FreeCAD file. The holes in this are sized to 3.8mm to allow 1/8" tools to fit with some clearance.x-extension-fcstd - 47.44 kB - 08/03/2020 at 10:41 |
dremel_bit_caddy_TTTTT.stlThe rotary tool caddy (other brands than dremel are available...) STL file.sla - 1.94 MB - 08/03/2020 at 10:39 |
end_wall_5hole_holder_flattened.FCStdThis is the tool hanger shelf FreeCAD file that is fitted to the end of the TTTT.x-extension-fcstd - 18.16 kB - 08/03/2020 at 10:39 |
TTTTT.FCStdThe main assembly of the TTTTT FreeCAD filex-extension-fcstd - 87.84 kB - 08/03/2020 at 10:39 |
