Lighting Color Control with Commodity Lamps
A controller system using consumer LED lamps to provide color temperature control and management alongside daylight dimming.
jonJon
CalEarth skylights and windows maximize the use of available daylight. Artificial lighting for such structures should respect and amplify the sunlight available, from the bright, white afternoon sun to the warm, red sunset.
Typical lighting control applications most commonly include occupancy sensors, may offer manual dimming controls, and in some cases are able to support automatic daylight dimming (i.e. daylighting).
This project will develop a method by which color temperature can also be a controllable element. The lighting source will be based upon commonly available light bulbs (selected for their individual color temperatures) . The system will use a spectrophotometer to characterize the individual color components of light.
Such a system could ideally be integrated into a small two- to four-light fixture and could provide a wide spectrum of effective color temperatures and illumination levels while opening up color temperature-specific applications.
Perhaps one of the biggest reasons to launch this project is a fascination with artificial lighting. Access to low-cost versions of what were once prohibitively expensive tools to quantify and control lighting (such as ambient light sensors, RGB sensors, and spectrometers) proved that the timing for a project like this couldn't be more right!
Seeing the open, daylit interiors of the CalEarth SuperAdobe structures also brings to mind a problem witnessed in even traditional buildings: the inability of typical artificial lighting to either leverage, mimic, or complement (and possibly intentionally offset) the existing daylight that enters a room. Often the rooms with the most daylight suffer from unattractive contrasts between the artificial source and the incoming light, while also failing to provide efficiencies that might be available could the light output be modified based upon a target light level. At the same time, rooms cut off from daylight often present stark color differences when viewed from rooms lit from different sources. Though such contrasting scenarios may be intentionally selected for should color temperature maintenance be prioritized over daylight matching, the fact is that few systems actually achieve either result as they fail to account for the effective color temperature of the ambient light received vs. the color temperature output by the light source.
Additionally, a key design goal will be to use traditional household lamps as the primary source. Rather than integrating a DC LED light source, modular screw-in lamps will be used allowing for a system whose color temperature range and output brightness are all modular and extremely flexible (while demanding that associated AC controller circuitry be incorporated).
As used in many a smartphone, television and computer monitor, an RGB sensor and ambient light sensor will provide light output and color temperature readings, respectively. A spectrometer will be used to provide deeper insights into the quality of light being generated with the hopes that enough insights might be gained to make this component an operational part of the lighting control system.
An obvious success marker will be the ability to perform fine color temperature controls at given lighting levels. However, in the long term the team hopes to inspire more lighting projects which boldly consider traditional AC-based lamps as their output source.
  • 1 × SparkFun RedBoard Qwiic An Arduino-compatible development board featuring the Qwiic I2C connector system.
  • 1 × SparkFun Triad Spectroscopy Sensor - AS7265x A board combining three (3) sensors; the AS72651, the AS72652, and the AS72653 to measure 18 light wavelengths from 410nm (UV) to 940nm (IR) and featuring the Qwiic I2C connector system.
  • 1 × SparkFun Proximity Sensor - VCNL4040 An IR presence and ambient light sensor utilizing the VCNL4040 and featuring the Qwiic I2C connector system.
  • 1 × Sparkfun RGB Sensor An I2C RGB sensor implemented using the BH1749NUC.
  • 1 × SparkFun Ambient Light Sensor High accuracy ambient light sensor with I2C interface based upon the VEML6030.
View all 11 components
  • Color Temperature Sensor Position Improvement
    Jon10/22/2020 at 04:38 0 comments
    In the prior setup all three light sensors were kept on a makeshift shelf in direct view of the target lamps. This was done to address features of the ambient lighting sensor, where having a fixed distance from the source could allow for precise light output calculations, and the well-documented spectroscopy sensor, which had a limited field of view.
    However, moving around the sensors while performing some additional testing recently provided a significant improvement in the ability of the RGB sensor to provide lighting color temperature numbers which correlate very strongly to manufacturer rated values. Without any additional calibration or adjustment to the color temperature calculation formula, positioning the RGB sensor out of direct line of sight with the lamps has produced color temperature numbers within 1% of manufacturer rated numbers - an order of magnitude improvement(!).
    LampLabeled Color Temp (K)Direct Position
    Calc. Color Temp (K)
    Indirect Position
    Amber LED2000K1745K2004K
    EcoSmart Soft White2700K2387K2738K
    This was an interesting development and has been part of the learning process with the selected RGB sensor. Clearly being in direct line of sight of the lamps was impacting the readings. This actually recommends a design we'd considered but not implemented in our first prototype in which a white card is kept at a 45 degree angle to the sensor board to encourage the measurement of the color temperature of indirect room light.
    Ultimately the model of RGB sensor we chose doesn't seem to have been as popular as other sensors in the community (such as the ISL29125 or TCS34725), nor is it as well documented by the manufacturer given that it was part of an intentionally limited-run product line (Sparkfun's SparkX experimental product line). We've had reasonably good results, but there's definitely been some trial and error along the way that could've been eliminated by simply selecting a more common option within the Arduino community (or at least one with a more substantial amount of manufacturer documentation).
    We're still having some fun with this prototype so look forward to some more posts (midterm exams kept the team away for the last couple of weeks - but everyone survived and is looking forward to some additional refinements!).
  • Successful Color Temperature Control
    Jon10/05/2020 at 10:01 0 comments
    One of our key goals for success has been met: we were able to manipulate color temperature output while holding light output steady in a two channel configuration. What you're able to see below is the EcoSmart Soft White and EcoSmart Daylight smoothly stepping between 46 color temperature values without changing the light output level. Views were recorded both from external to the lamps as well as directly in front of them. When watching the lamps the changes in brightness of the individual lamps are subtle in part because the camera isn't having to adjust for overall changes in brightness.
    The view from outside where the door and colorful boxes can provide some reference as to the color temperature changes.The view from directly in front of the lamps where the changes in individual lamp brightness are visible, but overall output is stable.
    The changes being stepped through above represent steps of as little as 50K in a range from 2700K up to 5000K. The light output variation in each step was limited to no more than a 10 lumens in any given step, with even lower recorded values for most (in terms as recording the typical difference if any was no more than 1-2 lux at a measured distance of approximately 2 feet). The most obvious place to see the shift is actually using the spectrometer, which really highlighted what is happening as the output is kept fixed.
    The graph charts the recorded color spectrum of the ambient light for each step of the controlled light output program. The labeled light wavelengths at the bottom represent blue on the left (410 nm) moving through green (535 nm) and red (680 nm) and beyond into the infrared.
    The warmest source setting, with light only coming from the EcoSmart 2700 K Soft White lamp, represents the bottom line. Each successive step significantly increases the contribution of the blue component of the spectrum which validates an increasingly cool spectrum. Also note how the spectrum is composed primarily of three primary peaks of blue, green, and red.
    Although the lighting output is controlling only the power levels provided to each of the two LED lamps, their constant color temperature outputs and likely comparable phosphors and control electronics mean that this controller is effectively controlling each of the primary color channels with some granularity. The balance of color components would be slightly different for LED lamp manufacturer and color type selected, but should generally hold true (assuming it is color temperature stable across its power range) that manipulating power input acts almost as a proxy for controlling the individual color components of the light.
  • Who Still Has Incandescent Lamps? Lighting Nerds...
    Jon10/04/2020 at 22:20 0 comments
    Part of the interest in this project revolved around building and testing tools we've always dreamt of having access to over a lifetime of obsessing over artificial lighting. Some of the fun we had involved color temperature measurements with sources outside of the commodity lamps selected for this prototype. This included, unbelievably enough, traditional filament incandescent lamps and halogen capsule lamps also rated for the same 800 lumens range as those selected for the prototype.
    One feature which was immediately visible in the Color Temperature vs. Power testing was the natural tendency of incandescent lights to shift their color temperature as they are dimmed. I've zoomed into the range previously examined for our LED sources to highlight that range here for a standard 60 watt incandescent and 60-watt equivalent halogen (the latter being commonly available today as an energy-efficient incandescent replacement option).
    Testing of color temperature readings relative to power levels for older filament incandescent and halogen capsule lamps.
    Note how unlike the LED lamps in the prior log, these lamps have a graph best expressed as a polynomial and represent shifts of approximately 10-20% in color temperature. This noteworthy distinction is significant in that it is a natural function of the method by which incandescent lamps operate, but not of the sources which have replaced them. This has led to manufacturers attempting to emulate this functionality on newer sources using various techniques... the availability of which convinced this team that the project we have proposed might even be possible!
    One problem we noticed in calculating color temperature values for these lamps was that the resulting number seemed far too low relative to expected values. This problem may likely be a function of skipping the calibration step and is likely exacerbated by the differences in spectrum between the LED sources and the incandescent sources (see our earlier entries comparing the normalized spectra of incandescent and fluorescent sources as well as the spectrum of LED sources).
    For anyone worried about our lighting bills, please rest assured that these lamps were returned back to their safe resting places in the "lamp and bulb curiosities" box and aren't being kept in regular service.
    A newer capsule halogen lamp on the left and an old filament incandescent lamp on the right. To produce a comparable amount of light (800 lumens) the incandescent consumes 60 watts (and doesn't really output a full 800 lumens) while the halogen does so with just over 50 watts... while all the LED sources used in the prototype do so with under 9 watts(!)
  • Color Temperature vs. Power
    Jon10/01/2020 at 14:19 1 comment
    The previous log used the light sensor to measure light output levels relative to input power. This entry will review how the effective color temperature is calculated using the RGB sensor. This value was then measured over a range of power settings to determine not only the ability to easily record color temperature, but the fluctuation of color temperature relative to power input (spoiler alert: for most inexpensive dimmable LEDs color temperature typically does not!).
    The color temperature readings were taken without prior calibration of the response of the associated sensor (BH1749NUC) using known inputs. However, even without that step the good news was that calculated color temperatures were generally in line, albeit around 10% lower, than the values claimed by the manufacturers. Though a calibration step may have likely improved the ability of the sensor to produce correlated color temperature values aligned with the manufacturer stated values, the fact that calculated values came close on the first try proved encouraging enough to continue on with the next steps.
    The process for performing this calculation is to convert the RGB values to XYZ values (each part of a standardized color space) and from there the values can be mapped to a coordinate space for color temperature. A sample of different light sources in addition to the lamps planned for the prototype were used to provide multiple unique inputs to the color temperature calculation. The results at maximum power are tabulated below:
    LampLabeled Color Temp (K)Calc. Color Temp (K)
    Amber LED2000K1745K
    EcoSmart Daylight5000K4742K
    GE Cool Daylight6500K6336K
    Without calibration the values calculated are already close to the rated/expected values. Note that there is often some natural variation between the rated manufacturer values and independently measured values given variances in the way color temperatures are measured. Some more detail in underlying differences will become apparent as we examine values recorded from the spectrometer. To be clear, calculating color temperature from RGB readings is an intentional simplification. However, using the values from the spectrometer would not necessarily be any more meaningful relative to manufacturer values without delving into the industry-specific measurement standards defined for this process. We'd certainly welcome any input from those who might have some familiarity with these specifications!
    So having achieved relative success in approximating color temperature readings with the RGB sensor, we then proceeded to measure those values relative to power levels. And the good news is that for the selected, commodity dimmable LED lamps they proved fairly stable across a range of power levels. We did have some difficulty previously with lamps supporting differing minimum power levels, so we attempted to account for that here by starting with a higher minimum power level for the tested range to produce meaningful values. Note that this means the range covered below represents output levels starting around 2-7% of maximum for the range of lamps. Though wider ranges could be reported we'd have to customize the output for each of the lamps.
    Note how for most of the examples a fairly flat, linear color temperature is recorded over the minimum (left) to maximum output (right) ranges. For the warmer range of lamps the increase in color temperature over the range of the lamp represents a shift of around 2% of the rated value. For the cooler lamps this increases to around 5%.
    Overall this stability should make combining these sources at different power levels to achieve a customized final output color temperature relatively easy to predict. These findings appear to recommend the use of such simple, dimmable LED lamps over more internally complex sources with dim to warm features such as those mentioned in a prior post. This relative stability is significant when compared to more variable sources,...
  • Lamp Output vs. Power
    Jon09/24/2020 at 08:15 0 comments
    The first results that were collected from the system were the normalized responses of the lamp light output relative to the power input. Rather than list the measured power level I've simply used the abstracted power levels used by the lighting controller board (a range from off at 66 to full on at 0). Although it was possible to calculate the measured lumens of each lamp once an exact distance between the lamp source and the sensor was measured, the method used to produce this graph involved using the rated lumens rating of the lamp as a reference relative to the readings measured by the ambient light sensor.
    A graph of the output (lumens) of each lamp versus the power level setting in the lighting controller.
    Right away there are a couple of curves that stand out for cutting across the others: that of the GE Cool Daylight and the Feit Amber lamp. I've included a halogen incandescent and Cree Exceptional Light Quality LED lamp in this stage as controls to provide some reference lines for what are otherwise lamps selected as commodities and not because they are highly rated for their compatibility with dimmer circuits (as is the case with the Cree).  Some manipulation of the data by changing the scale to logarithmic and reversing the order of the data amplifies what is happening.
    The same data with the vertical scale made logarithmic and both vertical and horizontal scales inverted.
    The halogen lamp reaches the highest point in this version of the graph, demonstrating that it has the widest range of lighting levels. However, this may not be entirely useful since there may be little to no value gained from being able to control light output at such low levels as single-digit lumens. In contrast, the Feit Amber has the lowest starting point on the graph indicating a short range from minimum to maximum brightness.
    The Cree and EcoSmart lamps have the widest graphs demonstrating that they make maximum use of the power output range of the dimming circuit relative to their supported brightness ranges. The narrower graphs of the GE and Feit lamps suggests that they would provide less granular dimming control relative to the other lamps.
    Of course, a big factor to consider here is the design of the dimming circuit. Though certainly worthy of a dedicated post, suffice it to say that the power control method used by this particular controller - known as leading edge dimming - is actually not of the type best suited to controlling LED lamps - that would be trailing edge dimming. As such, a circuit more optimized for controlling LED lamps might demonstrate wider control ranges for the Feit or GE lamps, and taller output light ranges for sources like the Cree.
    Ultimately the EcoSmart lamps have to be congratulated for performing very comparably to the highly-rated Cree in this particular measure. The GE lamp performance is somewhat disappointing given the prominence of the GE lighting brand, whereas the limited range of the Feit Amber shouldn't be too surprising or discouraging for what is very much a specialty lamp likely not intended for general illumination.
    As one of the target applications of this control system, we've already used this collected data to create what could be termed the ultimate dim to warm lighting range. Dim to warm LEDs like the Warm Glow series from Philips lower the output color temperature as the light is dimmed to simulate a similar result which occurs with incandescent lamp dimming. However, this color temperature shift is usually small, moving a 2700K lamp to 2200K when dimmed.
    Using the dimming data above and the full spectrum of the lamps targeted for this prototype it was possible to create a scenario where the lamp output at full brightness possessed a cool 6500K temperature and, while dimmed, took the lighting color temperature down the very warm (and perceptibly red) 2000K temperature of the Feit Amber lamp before finally shutting off. This can be challenging to properly capture...
  • Fixture Design (or a Lack Thereof)
    Jon09/24/2020 at 06:10 0 comments
    As our testing progresses we've been exceptionally fortunate in our ability to get all of the components working and operational in a timely fashion. What may be missing for some, however, is a view of our solution which appears like anything that would be labeled a light fixture rather than science fair. This entry will review the original design concept, current prototype, and discuss the possible applications and options we have considered to date.
    Let's begin with a review of the original project schematic. As demonstrated below the schematic began with a primary controller. This controller would be responsible for managing the communication path between the sensors responsible for measuring light levels and color components. Integrating these results into actionable output commands would also be directed from the primary controller to a dedicated lighting controller. The lighting controller's primary function is to interpret lighting commands into AC power line changes to the associated dimmable LED lamps (up to four).
    Original project schematic documenting the primary controller in communication with multiple sensors as well as a dedicated lighting controller controlling up to four (4) lamps using traditional AC power controls (in red).
    Implementing this design as a prototype has proven straightforward. As documented below the current prototype board retained a standalone lighting controller with connectivity to four lamps. The primary controller is currently deployed as a standard arduino board. Given the availability of numerous I2C-based sensors we've actually experimented with more sensors than simply the spectrometer and ambient light sensor documented in the original schematic. Although the spectrometer has provided insight into the distinctions between each lamps color spectrum, we've also had good luck with taking color temperature measurements using an RGB sensor board.
    The current prototype system with lamps, lighting circuit controller, arduino controller, and three (3) sensors for lighting spectrum analysis, lux readings, and color temperature calculations using an RGB sensor. And yes, we did use a shipping box as an integral part of the prototype!
    What might be rightly questioned at this point is how this turns into a usable lighting fixture? The good news is that this part of the design is incredibly flexible. Realistically, the only component which would have to be incorporated into a lighting fixture would be the lighting controller element. These electronics could be housed within or adjacent to most any existing 2- to 4- light fixture to provide the necessary local modulation of AC power. The primary controller and sensor network could also be integral to the fixture, or it could be wired remotely or even done wirelessly. Part of our goal in designating a standalone lighting controllers was facilitating that kind of separation. The primary controller and sensors are incredibly simple elements which are much more complicated in prototype form than they would need to be if implemented on a single PCB as a remote device (and even in their current form they're still incredibly compact!).
    In constructing our prototype we intended to remain abstract rather than choose a specific fixture design since we've imagined this concept having applications in multiple areas. From a simple overhead light, to a bathroom vanity, to an even larger fixture appropriate for commercial installations the fundamental concept was focused around color temperature control of commodity dimmable lamps. After putting in the hard work to construct their CalEarth building, I don't imagine anyone choosing the fixture design of our prototype as a centerpiece to their new home. However, I would like to imagine that whatever lighting fixtures are selected could incorporate some of the control elements we've evaluated.
  • The Joys of Conglomeration
    Jon09/21/2020 at 09:01 0 comments
    One of the stated goals of the project was to speed implementation through the use of retail boards rather than scratch-built circuits. Of course, this brings its own unique sets of challenges and rewards, a couple of which I'd like to highlight here.
    The primary controller and sensor elements have proven very easy to address and program. In large part this is thanks to the exhaustive and easy-to-follow documentation Sparkfun has constructed around the devices we sourced from them. Getting started guides have proven a valuable part of the experience above and beyond the usual starting points of datasheets or sample code.
    However, while the lighting controller board was also easy to start addressing using the code samples provided (evidenced by our quick success at blinking a light) perhaps one of the most valuable pieces of documentation was sourced not from the manufacturer but rather from an Amazon reviewer(!). That review clarified the performance of the board's dimming range. The range is addressable from 100 (full off) to 0 (full on), but values above 66 produce either no output or full output (the latter being the most unexpected/undesirable result). We have been able to validate the same performance quirks with the controller used in our design, and have adjusted our code to limit itself to the functional range of the device. At this time it is unclear whether the issue is related to a hardware or firmware element within the device, but I'm sure further examination of the board's design would be interesting (if we didn't have more pressing matters at this time).
    Lighting Controller - Top ViewLighting Controller - Bottom
    In addition to the control circuits and sensors integral to our prototype, the idiosyncrasies of the circuits within the LED lamps themselves also require consideration. As part of the initial testing we were clearly able to record the different ways in which different light sources perform with a given electrical output level. The lamps pictured below, from left to right, are the GE Cool Daylight, the EcoSmart Daylight, a high-efficiency incandescent, and a Cree LED lamp (the latter two being part of our initial testing rather than components of the prototype). What you can clearly see the Cree (rather brightly) and the incandescent (albeit remarkably dimly) coming on from even the lowest output levels available from the lighting controller. As levels are increased the EcoSmart and then the GE light both activate.
    Varying responses to increasing output power clearly visible from (L-R) the
    GE Cool Daylight, EcoSmart Daylight, incandescent, and CREE LED lamps.
    While we plan to incorporate quantitative measures of this response as part of our project, this speaks to not only the value provided by the sensors we've selected for this prototype but perhaps their necessity. While a design with integrated LED light sources could make assumptions based upon datasheet values, recording and utilizing lighting responses to power input could prove useful for not only the overall flexibility of the system but also for the value provided by abstracting the lighting generation layer from the control layer.
    More to come soon!
  • Prototyping has begun!
    Jon09/18/2020 at 19:46 0 comments
    The team recently added a link on the project page to the GitHub Project Dashboard. This should allow everyone to follow our progress during the final month of the competition.
    The prototyping board has been constructed and can be seen below. The primary purpose of this setup is to create a safe space for working with AC voltages. As you can see, traditional lamp fixture bases were used to hold the lamps. The AC dimmer controller board is held up off the prototype board using bolts and nuts as a standoff system. The lamp cords were routed underneath the board. All of this is intended to minimize exposure to the AC side of the circuit while working on top of the prototype board with the low-voltage sensors. This configuration should also keep the light sources close together and, as such, within the field of view of the sensors associated with the project.
    Sensor-eye view of the lampsLighting controller close-upUnderside with AC cables
    You may see that the lamp cords in the underside view are separated in some places. This was done to facilitate later non-contact current measurements with a clamp meter. Voltage measurements should be possible using the terminal contacts directly on the lighting controller.
    This is the first arduino project for everyone involved on the team, and we can already say that we've done our own variant of everyone's first arduino project: rather than blinking a low-voltage LED we've managed to blink an AC LED lamp!
    More updates soon...
  • Talking Trade-Offs: Color Perception and Color Mixing
    Jon09/02/2020 at 08:01 0 comments
    As mentioned earlier, fluorescent lamps attempted to address their color spectrum limitations through the addition of newer and more complex phosphors targeted to produce additional color wavelengths. LEDs have another option given their naturally monochromatic nature through the addition of more LEDs engineered to output desired wavelengths1. However, this method has challenges associated with the efficacy of different LED sources to produce light as perceived by the human eye. This design comes under the header of color-mixing LEDs (where LED light emission is the only source), and hybrid-LED designs (where one or more color-mixing LEDs are combined with phosphor-coated LEDs). Though both designs merit further discussion to understand their place in the present and future of white light LEDs, the role of the human eye in color perception also deserves examination.
    Earlier the low efficacy of filament light sources was demonstrated by highlighting their tendency towards producing energy in wavelengths invisible to the human eye (particularly as infrared heat energy). Wavelengths of visible light are not, however, all perceived with similar levels of sensitivity by the human eye nor are their means of production using semiconductor sources equally efficient. Just as CRI establishes the conformance of a light source of a given temperature to color rendering associated with an incandescent source, the luminous efficiency function (or eye sensitivity function) demonstrates that the eye has significantly different responses to each of the wavelengths of the visible spectrum. This sensitivity peaks at the green 555 nm wavelength. As expressed in luminous efficacy, it demonstrates that an ideal monochromatic source (excluding all other losses) could have a peak luminous efficacy of 683 lumens per watt. See the figure below for a chart of eye sensitivity.
    Of course, a monochromatic source would score some 0 CRI and as such be unsuitable for general lighting. However, it is this curve which high efficiency sources are exploiting by combining peaks in the blue and red regions, where the eye is less sensitive, to combine and produce a light which both appears white while providing suitable efficiency. Early fluorescent lamps did just that, producing high luminous efficacy while outputting only two primary wavelengths. Thus, they also suffered from the limited CRI possible with such a combination. Balancing high efficacy with acceptable CRI is the primary challenge for lighting such as fluorescents and LEDs (whose emissions and/or phosphors often exhibit emission in defined wavelengths rather than as a continuous spectrum as with incandescent light sources).
    LEDs seem an obvious candidate for mixing together different colors without suffering the energy losses associated with phosphors, but significant differences in efficiency exist today among LEDs operating at different wavelengths along the visible spectrum. The least efficient LED designs are those engineered to output at or near the 555nm peak eye sensitivity wavelength referenced earlier. This is commonly known as the green-gap (see the figure below) and is one of the reasons why phosphor-coated systems have prevailed over color-mixing only designs to date. While blue LEDs have achieved power conversion efficiencies of 60% and greater, red, green, and amber sources have been limited to 44%, 22%, and 8% respectively2.
    The normalized eye sensitivity chart also expressed as luminous efficacy.1
    LED efficiency as a function of wavelength.3 Contrast the trough in this curve with the peak in the chart to the left.
    Collectively these factors help to explain the popularity of the dominant LED system design based upon blue light LEDs. They also could be seen to recommend the approach we've taken to incorporate commodity white lamps rather than build a color mixing solution one wavelength at a time. Of course, integrating a color spectrometer will enable some level of understanding...
  • Color Commentary on Color Rendering Index
    Jon09/02/2020 at 07:00 0 comments
    Although the earlier logs regarding phosphors suggest that fluorescent and LED sources can be manipulated from relatively monochromatic emitters of photons into producers of white light, the quality of that white light must be quantified given the distinctive construction of its constituent color spectrum. Lacking the relatively smooth and continuous energy band of wavelengths associated with incandescent sources results in a performance difference as it relates to color rendering. A metric for this performance is the Color Rendering Index or CRI and ranges from 0 for a monochromatic source to 100 for incandescent sources (with typical values for LED and fluorescent light sources ranging from 80-90)1. The efficacy of a light source can be significantly benefited by limiting its energy output to a finite number of wavelengths, allowing the light to appear white while only generating a fraction of the wavelengths associated with the incandescent spectrum. However, the capacity of such a light to produce acceptable color rendering is a trade-off which has to also be taken into consideration.
    As documented in the first project log about color temperature, the color temperature of the light source defines the peak of the energy curve of the associated light spectrum. Lower color temperature light sources accentuate lower energy light wavelengths like reds and yellows (such as the light from an incandescent filament bulb). Higher color temperature ranges transition from white to blues with 5000 Kelvin to 6500 Kelvin range sources being most closely associated with balanced white to slightly blue daylight. Note that in these cases white is meant to suggest a balance of light energy as perceived for each wavelength. Lower temperatures (2000-3000 K) are typically described as warm, temperatures around 5000 Kelvin are labeled as daylight, and even higher temperatures (≥6500 K) are labeled as cool.
    These two metrics are important to consider in unison since CRI only measures the conformance of a source’s color rendering performance to that of an incandescent source of the same color temperature. However, the different color temperatures have naturally different impacts upon the way colors appear to the human eye. The example obvious to most would be the warm light visible when the sun is at the horizon (typically rated at 2300 K) versus the sun in the noon sky (5000 K). The strong presence of red wavelengths emanating from a 2300 Kelvin source would suggest that a white (or any other) object would naturally appear more reddish regardless of the rated CRI. The CRI can identify the possibility of unintended color shifts for any given source at a specified color temperature when compared to a source of a different type at the same rated color temperature. However, the CRI does not preclude the presence of color shifts which are a function of a given color temperature. At the same time, personal preferences and historically established expectations may ensure demand for lighting options at every color temperature range.
    If CRI is a primary distinction to be overcome between efficient lighting sources and the incandescent sources they replace what other drivers exist to maximize color performance? Well that will be a great subject to tackle in the next project log!
    1 Color Rendering Index (CRI) Explained.” Full Spectrum Solutions, Full Spectrum Solutions, Inc., 2 Aug. 2017, www.fullspectrumsolutions.com/cri_explained.htm.
View all 16 project logs
dbcorbin wrote 09/30/2020 at 21:04 point
Controller error is a 6 bit rollover on some counter...    2^6 is 64... if they started counting with 1 instead of Zero, they get 65 instead of 64.   Then the counter rolls over at 66... which is the same as Zero again.   As you say, you can catch it in software.
Jon wrote 10/01/2020 at 05:46 point
Great insight!
Although the obvious answer for some might be "just build your own" what I'd really love to see in the dimmer control space in an option like Sparkfun's Quad Relay where they not only document the firmware within the local microcontroller but also appear to have provided programming pads (on the underside of the board) to facilitate modifying that code(!).
https://learn.sparkfun.com/tutorials/qwiic-quad-relay-hookup-guide#resources-and-going-further
Thanks for the post; I hadn't sat down and thought about driver for the error beyond "something must be wrong in the microcontroller code."
