Assembly
A project log for M&M Dispenser (for research use only!)
Push a button, get a treat!
lex-kravitzLex Kravitz 08/06/2020 at 03:220 Comments
Here are photos from the assembly.  If anyone is interested in replicating this I can write up more detailed instructions.
Assembled ULN2003 stepper wing with IR beam-break (for detecting pellets) and 4-pin circular connector attached (for connecting to light-up button)
3D parts, assembled button, and plant:
Installed stepper into 3D housing:
Dispensing disk attaches to stepper with an M3  brass insert and set screw:
Feather board goes here:
ULN2003 stepper wing goes on top:
Front view showing photobeam clicked into the 3D housing (there are screw holes but they aren't really necessary):
Final assembly
