1Installing Display In Frame:
- Take the upper frame and a piece of color cardboard.
- Mark the display dimensions on the cardboard and cut it.
Attach the cardboard to display using plastic tape.
Clean the glass and display and put the display into the frame.
With the help of supporting cardboard fix the display.
2Installing Electronics In The Frame:
- Take the lower frame and mark the positions for cooling fan vent,head phone jack,USB ports power plug.
- Cut the markings.
Put everything in the frame using screws and double tape and seal the photo frame.
