Features:
-For up to 3 computer fans
-Accepts standard 3-pin or 4-pin (PWM) DC fans
Up to 1 Amp for 4-pin
Up to 0.3Amp for 3-pin
-Can be directly plugged into a 4-pin fan connector on your mainboard
This supplies power, while also allowing for communication between mainboard and fan controller.
-With the new TimeFreeze LED effect
Applications:
-Casemodding: It adds a cool visual effect to your fans, making them appear to spin reeeallly slowly.
-Silencing: Beating frequencies/interference between fans can be eliminiated. This makes the noise much more pleasant.
Compare this for yourself:
Without synchronization:
https://cdn.hackaday.io/files/1741597451218656/fanasync.m4a
With synchronization:
https://cdn.hackaday.io/files/1741597451218656/fansync.m4a
(Both tested with 50mm fans at 3400 RPM)
-Fan signal adapter: It generates three ouputs from a single mainboard connector.
-Allows for regulation of 3-pin fans over a 4-pin mainboard output!
Reccomended operating conditions:
-Up to 3 standard computer fans of the same kind
-The TimeFreeze effect will shut off below a certain RPM limit. This limit is given by RPM=3600/<Number of fan blades>. Make sure to stay above!
Example: For a 9-bladed fan, the minimum RPM will be 3600/9 = 400 RPM.
-For fans which don't have to change their speed very often - case fans, watercooling radiator fans, etc.
t.oster92
For Q4 and Q6, i used a double transistor (MBT3904). It should work with discrete transistors aswell.
JP Gleyzes
Vitaly Rudik
