MT3608 SEPIC
Simple non-inverting Buck/Boost Converter
Simple single ended primary inductance converter (SEPIC) based on the MT3608 with a fixed output voltage selectable by the resistor values of the voltage divider.
Stefan Wagner wrote 11/06/2020 at 17:03 point
Hi, yes, the MT3608 is a boost converter IC, but it's possible to build a non-inverting buck/boost converter out of almost any boost converter by using the SEPIC configuration which requires a second inductor. For a more in-depth explanation refer to: http://www.ti.com/lit/pdf/SLVA337
Barbaros Kucuk wrote 11/06/2020 at 13:29 point
Isn't MT3608 just boost converter ? How do you do buck ?
