Start
A project log for Freeform Humidity Pressure Temperature session
Arduino powered GY-21 and BMP280 station using an OLED display.
ben-harveyBen Harvey 08/08/2020 at 22:520 Comments
I decided to start putting together the main components of the station today. I have been waiting on a new soldering iron as the tip on mine is broken and while it works, it ain't pretty.
When I lined up the components, most of the holes for the SCL/SDA Ground and Vcc connections were in the same place. Only the Ground and Vcc on the OLED were swapped around. I bent some brass rods around to cope with this and soldered it together.
Next I'll work out how to connect the Arduino.
