Non-tech snail mail notifier
A legacy mail notifier made from a candle lamp and other things.
Public Chat
0 followers
Wife wants a legacy mailbox notifier, so I went to the local flea market to see what I could find.
Project finished! An old candle lamp hos got it's foot crammed with tech, to make a non-tech appearing mail notifier.
The notifier: A lamp that rotates when new mail has arrived.
Graphics Interchange Format - 2.80 MB - 08/11/2020 at 15:15
Preview
Download
  • 2 × Wemos D1 Mini
  • 1 × Cotterpin
  • 1 × Washer
  • 1 × Shrink tubing
  • 1 × Bushing Some kind of plastic bushing
View all 6 components
  • De-digitalised mail notification
    Altairish08/11/2020 at 15:20 0 comments
    So I want a physical notification when I get a new snail mail. I went through the local flea market and picked up a nice candle lamp for $1.
    I tried fitting it with LEDs to make a visual notification, but it seemed too easy. Besides, I want the notification to be as little technology reminding as possible. So I came up with the idea that it should rotate when a new mail has arrived. It took a lot of work and hot glue, but in the end it turned out great.
    To make a stepper motor, control board and a D1 Mini fit in the base, I ended up using enough hot glue to basically make the whole base water proof.
    Hot glued a encoder knob inside the stem of the lamp, to have something for the motor drive to attach to.
    Finally super glued the lamp stem to the motor drive. So everything above the base is rotating. See video for demo.
  • McGyver switch
    Altairish08/09/2020 at 20:54 0 comments
    After some rummaging about in the dark corners of the house, and yet more experimenting, I arrived at the following design:
    So a cotterpin slides in some kind of plastic tube, and  when the head of the cotter pin touches the washer, the ground and RST of the Wemos D1 Mini will be shorted, hence waking it up.
View all 2 project logs
