SCE2-M tiny stepper controller module
Fully integrated stepper motor controller module for digital control for limited space applications
Public Chat
SCE2-M is a fully integrated stepper motor controller module for digital control for limited space applications. Designed for small 3D printers, laser cutters/engravers, CNC mills, pick and place machines, robots, test fixtures, and other motorized devices. SCE2-M module is the smallest motor controller that requires no external components and runs industry-standard g-code processor with linear interpolation control open-source GRBL firmware running on STM32 MCU.
Features
  • System On Module (SOM) design
  • Fully integrated, ready to use
  • 4 stepper motors drivers, up to 1/256 microstepping
  • 4 Limit switch inputs
  • Direct connect USB port
  • Optional TTL USART/I2C ports 8 IO ports (some with hardware PWM output capability)
  • 32bits ARM-Cortex M3 microcontroller, running at 72Mhz
  • Advanced motor control with Trinamic drivers
  • Digital current control of stepper motor drivers directly from g-code
  • Direct access to TMC2300 registers over g-commands
SCE2-M.zip
STEP 3D model
x-zip-compressed - 161.00 kB - 09/27/2020 at 06:06
Download
  • 4 × TMC2300 Trinamic motor driver
  • 1 × STM32F103CBU6 Microprocessors, Microcontrollers, DSPs / Microcontrollers (MCUs)
View all 3 project logs
