Hackaday.io Hackaday.io
Sign up Log in
DSP Audio : 4 OUT - 2 IN
I thinked to made an electronic device that used for audio treatement
aymenaymen
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
808 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
325
0
808
4
Team (2)
  • aymenaymen
  • ronaldoscronaldosc
Join this project's team
ongoing project
hardware
Related lists
RECRACK - resources
Collection of resources for our standalone "interposition-transparent" multichannel DI/splitter/recorder unit project.
This project was created on 08/11/2020 and last updated 4 months ago.
Description
Hello Hackaday makers, I would like to ask for advice about an idea I’m developing. I’m thinking about creating a low-cost audio processing system for music lovers. The device would have two audio inputs and four outputs, and a desktop application would allow users to configure the device and apply audio processing such as: Equalizers to correct the sound for the four outputs Limiters to protect amplifiers and speakers High-pass / low-pass filters (Butterworth, Bessel, etc.) for crossover applications Routing options: L / R / L + R I am planning to add a USB interface for communication with a computer. For audio connections, I’m considering using screw terminal blocks with balanced audio connections. On the front panel, I would like to include: VU meters for the inputs Four push buttons for quick mute control LEDs for clip / mute / signal status One challenge I’m currently facing is implementing delay due to the DSP limitations. The hardware I
Components
  • 1 × ADAU1401 Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 1 × PL2303 Interface and IO ICs / USB converter
  • 1 × atmega328p Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
Project Logs
Collapse
  • using an exesting board to make first tests
    aymen • 10/21/2023 at 11:57 • 0 comments
    I got a preamplifier from DBtechnologie to perform tests
  • Control blocks by msu
    aymen • 08/26/2020 at 08:49 • 0 comments
    I try to use arduino to control volume multiplex blocks
    Good news i can control it
    Now trying to do sale think with parametric equalizer
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The simplest and cheapest way to make a stand-alone analog quality VU meter with instruments from an old unusableaudio audio device
Project Owner Contributor
DIY Analog VU meter with Arduino peak meter
mircemkmircemk
This device is used to transmit audio signals over long distances using RJ45 cables without suffering from noise and attenuation
Audio Extender: A DI Box for Clean and Noise-Free
aymenaymen
A device that adds volume control over WiFi to balanced audio
WiFi Balanced Audio Volume Control
adam-demuriAdam Demuri
TPA3116D2 based audio amplifier
KAmp
kuroKuro
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DSP Audio : 4 OUT - 2 IN", please tell us the reason.
Send message
Remove Member
