mutantC v3 - modular and powerful handheld PC
A Raspberry pi UMPC. An open platform device to use and fit your project .It is fully open-source hardware. So you can hack it as you wish
You can make your expansion-card like GPS, Radio etc and attach them. You can access all the ports of the pi and the back part is attached with 4 screw. It can hold a 4" or 3.5" touch screen. Also have a physical keyboard attached via USB. It don't need any custom image of Raspbian. You can use vanilla Raspbian and install the LCD driver, that's it. This device can controll your ROBOTIES, QUADCOPTER use for HOME AUTOMATION, LONG DISTANCE MESSAGING and many more with one device. Also deploy bunch of mutantC in the field and use for managing your big projects, use the DOCKING port to collect data from all of them easily.
Checkout the poject website from here.
A Raspberry-pi handheld platform with a physical keyboard, Display and Expansion header for custom baords (Like Ardinuo Shield).
It is fully open-source hardware with MIT. So you can modify or hack it as you wish.
It is platform like Arduino. You can make your expansion-card like gps, Radio etc.
So help us to make a Community around it.
See a 3D view of mutantC from Fusion 360 Online Viewer.
Parts list.
Follow this guid to build one Instructables.
Follow this link to order all 3 PCB from PCBway, click here.
Featuers that comes with V3
  • Have RTC & buzzer.
  • Supports a lots of Add-os, see all of them from here.
  • 5 row, 56 key customizable keyboard
  • A track point to have mouse support with left, right buttons.
  • Gyro support using MPU6050 module & presure, temp and humidity support usin BME280 module.
  • Able to turn of modules, Display, Add-ons using keyboard button.
  • Full poweroff using OS and keyboard key.
  • 12 pin docking port beside Pi USB ports with UART, I2C, Charging and GPIO.
  • 3D parts are more solid and reduce supports when printing.
  • Able to read battery voltage using Pro Micro.
  • 2 LED's connected to Pro Micro with PWM support and 1 connected Pi. Move the stema/Qt I2c connector bottom so it is acessible from outside.
  • It is fully open-source hardware. So you can Hack it as you wish. You can make your expansion-card like gps, Radio etc and attach with it.
  • You can use any Raspberry-pi form factor like Asus Tinker Board S / PINE H64 Model B/ Banana Pi BPI-M4B etc. You can use Raspberry-pi zero to 4.
  • You can access all the ports of the pi and the back part is attached with 4 screw.
  • It can hold a 4" or 3.5" touch screen. Also have a physical keyboard attached via USB.
  • 18650 battery with charge and discharge protraction .
  • You can use Littlevgl make UI that don't need a OS form here.
  • It don't need any custom image of Raspbian. You can use vanilla Raspbian and install the LCD driver, that's it.
  • So little parts needed to make one. See the parts_list .
  • You can use C Suite Application suite made more touch based device in this. This apps are suitable for small screens. See the C Suite.
  • Added Adafruit STEMMA QT and SparkFun qwiic connector.
JPEG Image - 2.93 MB - 09/07/2020 at 10:21
Preview
JPEG Image - 2.94 MB - 09/07/2020 at 10:21
Preview
JPEG Image - 2.75 MB - 09/07/2020 at 10:21
Preview
JPEG Image - 2.79 MB - 09/07/2020 at 10:21
Preview
JPEG Image - 2.65 MB - 09/07/2020 at 10:21
Preview
View all 38 files
View all 13 project logs
