Sneak peek to mutantC v4 power circuit
02/12/2021 at 12:02 • 0 commentsI am testing the new power circuit for v4, this black PCB are from PCBway and that helped me to quickly test out the new changes. The production was fast and i got the PCB within 3 days.
I had to make the v4 because of 2 reasons, the power supply is not enough and a lot of tiny mistake i made on the scolding pads. now those pads are bigger and easy to solder.
But V4 and v3 are not compatibles in the size so there is no drop in replacements. -
Some updates on power and dock connector
01/24/2021 at 09:21 • 0 commentsI am thinking to use the module called MH-CD42 to replace the 2 module i am using for power.
Builds from Polarity Works
12/13/2020 at 04:37 • 0 comments -
New Colors
11/20/2020 at 09:33 • 0 comments -
Wanted to share this v3 industrial look
11/16/2020 at 05:12 • 0 comments -
Community​builds
11/14/2020 at 05:23 • 0 commentsHere is some pictures from some builds from communities. community.
Message to hackaday and A replacement in a part
10/25/2020 at 02:48 • 0 commentsHi, My project is a small one and easy one. Even though hackaday covered v1 and v3 and got attention but i don't know why it did not covered v3 yet. V3 is the finest among other two and more easy to build. I hope hackaday will cover it in their blogs and let people know about it.
PART UPDATE
An update on headers, use this headers, 2.54mm pitch x 5mm height female headers instead of old size one.
i can't find that header in the amazon or aliexpress. fond this but they are smd part. if you find the part in through hole then let me know here.( I got mine from local shop)
https://www.amazon.com/2-54mm-Female-Plastic-Gold-Plated-PH5-0mm/dp/B07KM261B8?th=1 -
Order your prebuilt mutantC v3 (not officially)
09/25/2020 at 17:03 • 0 commentsSo open source licensing is paying off.
As mutantC is a open source hardware and I am not capable to supply you guys one by tindy or other way, so kwlodraczyk took the job to supply you guys one by his own.
I saw this post in Reddit and that made me so glad so I wanted to shear.
mutantC v3 - Full feature overview
09/08/2020 at 10:34 • 0 comments -
mutantC v3 preview
09/07/2020 at 12:14 • 0 comments
