single line mode test
A project log for Daisy Kite Airborne Wind Turbine
Ram air kites spin a parachute and transfer torque to ground
roddy-rags-readRoddy "Rags" Read 07/13/2014 at 20:030 Comments
The Disy ring was tested directly inline with the lifter kite.
Configuring this way I had no direct control over the tension in the rotation axis... (actually I had a light back line behind which could take the back end down if needed)
Anyway, Here's the "proto promo" / test vid... I just happen to have been brought up and live on a gorgeous island. So handy for backgrounds
http://youtu.be/t4cebOOEP4w
