COPXIE - chainable, dual 5*7 tiny led matrix
Small project inspired by #PIXIE. Software and Firmware compatible but using discrete LEDs instead of dot Matrix modules
This project is inspired by #PIXIE - Chainable, Dual 5*7 Micro-LED Displays!
@Lixie Labs did a great job of writing Firmware for the Attiny and building the whole Environment.
Some main Features:
  • compatible to Pixie
  • can use same Firmware on the Module
  • can use same Library to control them
  • using discrete LEDS instead of Dot Matrix Module
  • compatible Pin header but with some additional pins fore easier chaining.
  • Can be also Mixed with PIXIE in same chain
Adobe Portable Document Format - 90.85 kB - 10/28/2020 at 20:20
Preview
Download
View all 4 project logs
