3D printed Test-Jig
A project log for COPXIE - chainable, dual 5*7 tiny led matrix
Small project inspired by #PIXIE. Software and Firmware compatible but using discrete LEDs instead of dot Matrix modules
alexAlex 08/14/2020 at 23:130 Comments
These picture may be familiar for you from Twitter (https://twitter.com/tinyledmatrix/status/1282358115078414341). But will also put them here to get a more permanent space.
I designed this little Test jig to program #COPXIE - chainable, dual 5*7 tiny led matrix without needing to solder the Pin header. You can program the Attiny and test the SPI communication afterwards.
Copxie PCB test fixture with 3D printed parts detail view
https://pbs.twimg.com/media/EcvZRWJXoAETG3p?format=jpg&name=small
