I've made the board fairly generic so a single layout can be used in multiple situations. By default it's setup for a 6 cell, 12V lead acid battery but can easily be modified for Li-Ion, 24V, 48V etc by varying component values. Check the datasheet for more information.
Intended use is for DC-DC battery charging of an auxiliary battery from a vehicle alternator. I would also like to see how it performs with a solar panel but there is no MPPT tracking at this stage.
The component footprints are a bit of a mixed bag because I am using what I already have in stock. I've used PLCC LEDs for example because I still have hundreds left over on a reel I originally purchased in the 1990s!
